spinningmagnets
100 TW
I found the graphic posted by Chalo to be very educational, I had previously assumed a bike rim would be more rigid and the majority of the force of a pothole hit would be transferred to spokes on the opposite end away from the pothole. (imagine a bicycle traveling from left to right, pothole strike is at 5:00 O'Clock on the wheel). I hadn't considered that the force would try to pull the rim into an oval shape, and this would transfer some of the forces to other spokes that are far from the opposite end of the hit.
I can't help but to suspect that there are a couple/three methods of fixing the "broken spoke" problem at play here.
The LFP/Chalo method [picture shown] was for a non-hub, (20-inch wheel/moped tire?...on a hardtail, street use).
When researching the Raptor using a Cromotor, found this:
"...You should really only use a 19″ prowheel [motorcycle] rim in the rear...If you insist on using small spokes, go 12-Ga minimum. High quality 12-Ga will be adequate, but 8-Ga to 10-Ga is better, though…”
This advice was for a heavy Cromotor, heavy Shinko motorcycle tire, 2-cross spokes, on a frame with a long rear suspension travel.
It has been my understanding that one of the benefits of the Cromotor was that its diameter being smaller than the Crystalyte 5-series made the spokes just longer enough to dramatically improve the broken spokes issue. (is the large-diameter 5-series/extra short spokes combo the worst offender?)
Maybe the non-hub LFP/Chalo method (taken from the pedal bicycle world) uses flex to its benefit, but...the Raptor/Cromotor method overcomes the issue with a very heavy non-flexy method that is only useful for a specific user-profile? I'm trying to learn...my mind is open...
