docw009
I am going to re-lace a new fat bike rim to a motor kit that came with a 26" mountain bike wheel and 12G spokes. The motor came with holes for 12G spokes. I would like to use 13G spokes in the existing holes, but the holes seem to be about 3mm diameter and are countersunk on each side, so maybe washers would not work well. That's my question. Could I get away with 13G?
Otherwise, I'll just buy cheap chinese 12G spokes? They were on the motor prior. The rim will need to be drilled for the bigger nipples too. Never as easy as it sounds.
By the way, it's a 135mm drop-out going on the front. I took the freewheel off, and will shift some washers around for better centering, I expect it might need some dishing to keep the tires from rubbing. That means two sets of cheap chinese spokes.
