Allex
Yes it is indeed quieter! Glad you have it working.
Keep your smelly Cherokee as a reserve
Mine smells too, even after I cleaned the board and drained it in alcohol.
Allex said:At 16S you could probably take 200Amps from it. But you need to load the unlocked firmware to make it happen.
at 20s 150Amps is not a problem. (it's locked to 150A from factory)
Allex said:Never thought about that actually
But when I think about it, around 4000usd spent on upgrades![]()
Rix said:Allex said:At 16S you could probably take 200Amps from it. But you need to load the unlocked firmware to make it happen.
Man that's plenty. Thanks for the response.
Allex said:Yeah I would not mind move down to Australia to get some more saddle time with their climate!
stevebills said:why do bombers and fighters come with cheap nasty from forks as standard when they charge a premium for there bikes?
stevebills said:so what forks are standard on the fighter?
Any reason u didn't use a phasor frame instead?
