Rodney64 said:Fitted the throttle and batteries
[][/url]
Also wired up the circuit breaker so all I need to do now is fit soldier the hall wires.
I'm using a 120 amp circuit breaker. I will need to set max amps on the max-e at 120.
pg[/img][/url]
9lives said:Rodney64 said:Fitted the throttle and batteries
Rod, what throttle are you using? Looks like a moto throttle from image.
the bike feels good Kelper. Just need the seat up a bit higher. Standover heights good for me as well.Kepler said:Bike looks great Rod. The small splashes of red really suit the white frame. Size wise, the bike looks to be good fit for you too. Look forward to hearing how the bike performs and how it compares to other builds you have done.
Rix said:Rodney64 said:Fitted the throttle and batteries
pg[/img][/url]
Rod, I like your bike. Whats your initial impression riding around under pedal power only? Your bike looks like an old school TT short tracker. How much clearance do on between the sides of the swingarm and tire?
Samd said:Laced up a 24*50mm front rim with a 3" berm master
Unfortunately the 19*3.75 inch rear tyre ain't gonna cut it.
Pass me the five inch grinder dear.
Unfortunately schlumpf hsd looks like at least a 30 tooth front is needed to clear swinger.
Equivalent to a 75t front![]()
Yeah what a hackKepler said:Hey Sam. You might be able to build a good ebike but your photography skills suck.
Step up young man and give us some better detail.![]()
Rodney64 said:9lives said:
Yes it a motorcycle throttle, testing at this stage. Domino Motorcycle Cable Throttle.
[][/url]
pg[/img][/url]
Felt good Rick, not too cramped and it will be good for pedalling. My knees never touched the sides. The clearance between the tyre is 10ml exactly on each side.
Samd said:Reamed the bb and added a schlumpf hsd but need to check chainstay clearance for chain.
fullonoob said:Hey Im ready to order my rear shock. which one should I go for?
1. http://www.amazon.com/gp/aw/d/B00FLTZ2ZS/ref=mp_s_a_1_1?qid=1439853386&sr=8-1&pi=AC_SY200_QL40&keywords=dnm+shock&dpPl=1&dpID=41aSiUPmucL&ref=plSrch
2. http://www.amazon.com/gp/aw/d/B00LM3FPMC/ref=mp_s_a_1_2?qid=1439853386&sr=8-2&pi=AC_SY200_QL40&keywords=dnm+shock&dpPl=1&dpID=51I5JHoG4zL&ref=plSrch
3. http://www.amazon.com/gp/aw/d/B012C9ZF10/ref=mp_s_a_1_11?qid=1439853745&sr=8-11&pi=AC_SX110_SY165_QL70&keywords=dnm+shock
Shock length is 220mm and unless you're quite tall I reckon this is the way to go. With the seat post right at the bottom and adjustability in the shock mount it will suit people down to 5'6" up to around 6' before you even start to play with the length of the seat post.chilau2000 said:Hi Hiyena
A few questions on your build ?
Rear shock length
Hubmotor and spoke gauge
You'll need the special milling tool. Unless you already have it I was planning to buy the tool and do this so it's already supplied pre-done. I'm thinking I would also need to supply the special box spanner that's used for inserting the drive. The tool is $200+ so you guys don't want to have to buy that but the box spanner is only $20 and it's both necessary for installation and useful to have if you even want to remove the drive for servicing or replacement. If a group of you in each country want to share the spanner you can but for $20 I would think it's probably not worth the shipping costs to bounce it around.fullonoob said:How hard is it to ream the bb?
Hyena said:Shock length is 220mm and unless you're quite tall I reckon this is the way to go. With the seat post right at the bottom and adjustability in the shock mount it will suit people down to 5'6" up to around 6' before you even start to play with the length of the seat post.chilau2000 said:Hi Hiyena
Rear shock length
Hope motor and spoke gauge is 'choose your own adventure' depending on how and where you ride. On this build mine will be a mid spec hub motor and either adaptto mini or maxi
