Kepler
I have been though the same issue over many years of riding. I have always liked to pedal even on high powered bikes at high speed where my input is doing F-All but also have the ability to pedal home if needed. Tried lots of combos but i think I have come up a solid economical solution on my Beta 29'er build.
Setup is as follows.
Mxus 2 motor with a dnp 8 speed 11-34
Entry level Shimano Altus 8 speed derailleur and matching rapid fire shifter
Chainring end:
130mm BCD spider with dual chainrings.
Large chainring is a 54 tooth but has a narrow / wide tooth pattern. This is the key to keeping the chain on under rough conditions.
Small chainring is 39 tooth standard chainring and is my "get me home" chainring if I need to pedal home. No front derailleur. I just manually put the chain on the small chainring if ever needed. So far, I have never need to do this so its only going to be a rare situation to use the small chainring.
Custom chain keeper mounted on the swingarm shock mount that wraps over the front of the chain only and acts as last line of defence. A large diameter chain guard would do the same job but its hard to find one that suites a 54 tooth chainring.
I could have used a schlumpf and had one ready to go however I opted for the large chainring because it gives me better chain to swing arm clearance and reduces chain slap considerably.
Other items of note is that the 8 speed dnp is screwed flush onto the motor housing so I could squeeze it all on on a 135mm dropout. Even then I needed to spring the swingarm out by an extra 5mm to fit it all in. It also means I can't shift to the largest gear on the rear but i can live with 7 usable speeds.
This combo allows me to pedal comfortably right through the bike's speed range up to 60kph and will get me home unassisted if needed.
Chainring end:
