chucho
Samd said:https://vimeo.com/153836396
Speakon port replacing key switch is going well.
Very nice!! Same one i have
Soft motorcycle saddlebags would carry the pack.Samd said:Idea is I can throw a range extender pack over the frame with both packs hoc and pull 40a from each.
Samd said:Actually I opened the beta box that has sat unopened since Xmas. Battery drops in with 3mm to spare.
Time to order another!
Samd said:I went with Sanyo (Panasonic) 18650GA 3500mah cells. Thats a very tidy 18s 21ah pack.
I got cheeky and fitted an 80 amp BMS even though these cells don't want much more than 10 amps per cell burst (you gotta pay the piper somehwere between density and surge current).
Its pretty torquey so I tend not to use 80 amps for very long - and in reality I am going from 10a per cell to ~12amps.
Allex said:Here are the results.
Interesting to note is that 30Q actually gives you more capacity down to 3V, probably due to less volt sag. First if you start do drain it below 3V that GA have more to give.
We also see that 30Q doesn't really care if the load is 7 or 10A(It is a 15 or even 20A rated cell), it gives you almost the same capacity, but GA is of course more sensitive. The temperature is also noticeably lower on 30Q which gives us longer cell life this is of course due to lower Ri.
But this test is during a constant load of 7 and 10 Amps. We don't usually ride at full throttle do we...
Samd said:Mine are going fine tesla.
Rix said:Very nice Fullnoob! how long till you up and riding?
