mpmoller
- Joined
- Oct 22, 2017
- Messages
- 48
Hi ES.
I am getting a strange problem. I have recently changed my frame to a new frame (FUTR ALPHA). I am using my old Midi-E and Mxus v3 3k motor.
At a sertain point where the wheel is still there is no hall error. When I turn the wheel the !HALLS! error appears.
https://youtu.be/OcXteK3OIt0 (Its my brake the is squeaking in the video. I move the bike a small bit, and then the error turns up).
Things I have tested.
1. Running the motor in sensorless mode (SLESS) in the adaptto menu. No problem, ran but shitty like sensorless mode is. Phase-wires should be good then.
2. Error screen (2 presses to the left on the adaptto screen). No problem with changing from H1,2,3,4,5,6 and so on.
3. Tried running autodetect in adaptto. Runs for 2 seconds then gives me a "HALLS E1".
4. I put a multimeter on the ground (black) and the yellow, blue, green hall-wire as in this guide; http://www.ebikes.ca/documents/HallSensorTestingFinal.pdf
When i turn the wheel they change the voltage from 0-5v as they should.
I added storade to the motor when I assembled the bike. He is 2 pictures of the motor before i added storade. Does anything look off?
Tried anything similar?
Any suggestions? This is driving me nuts.
BR
Mpmoller
BR
Mpmoller
