HolgiB
- Joined
- Oct 2, 2018
- Messages
- 70
Hi all,
In the last time I have had strange issues with my MAC hub motor running together with a PAS sensor, KT36 / 20 Amps controller and LCD8. It is kind of hard to explain. So I rather link to my video (please ignore the German text
https://www.youtube.com/watch?v=5wUuqlKUeLk
I see those break downs only at higher power levels (4-5) which translate to ~ above 400 watts. It seems to me that the three phase wires running parallel to PAS-Sensor cable cause disturbances. I have had similar issues with my old 9C RH205 hub motor which I used prior to the MAC.
I already exchanged the controller to a smaller 14 amps peak KT36 but the issue remains.
My questions:
- Has anyone of you run into similar issues ? I guess the higher phase current, the more prone to influence those sensor wires become.
- Would it make more sense to add shielding to phase wires or the sensor cable ? I was thinking about wrapping it with aluminium foil and use some short wire to ground the improvised shielding.
- Or should I exchange the unshielded sensor cable to shielded cable ? (e.g. microphone cables).
Thanks in advance,
Holger
My questions:
Thanks in advance,
Holger
