I’ve been lurking here for a while, can I just take the opportunity to thank everyone for what a fantastic resource this forum is, I’ve learned so much here. Now it’s time for me to ask for help with a stubborn problem.
In brief, I’ve got a combination of front geared hub motor, controller and 48V battery (12S lipo) that tops out at around 11mph and refuses to go any faster (also apologies for mph in general, the UK is apparently a metric country, except where it isn’t. What with all the road signs and local regulations being in mph I’m kind of stuck with it). My own investigations lead me to believe I’ve been unlucky and bought an incredibly slowly wound motor since the problem doesn’t seem to be controller or battery related. Before I go ordering another motor I’d like to see if there’s anything I’ve missed.
The hub motor I bought is listed here. It’s a good price and I figured a lot of these 250W hubs are similar so I’d be fine with it. Note it’s a 36V motor which makes me surprised it runs so slowly even on 48V. I’m currently using it with a sensored controller (from here) although I tried a sensorless controller and had exactly the same top speed. That should rule out any issues with the hall sensors I assume. The controller is connected to one of those basic LED (not LCD) displays and I’ve also tried shorting the controller on directly with no change in the speed either. I’ve tried both twist-throttle and PAS sensor and both work but neither changes the top speed. Batteries are two 6S 16AH lipos in series, I’ve used lipos for a few years in RC so I’m pretty familiar with them.
So that’s about the extent of it. With the bike up in a stand and the wheel running off the ground the max speed is about 11.5mph, I measured the voltage across the phase wires with a multimeter on AC mode and see about 48V if that’s of any use. Current consumption with no load is minimal. The motor runs smoothly and quietly with plenty of torque on hills, there’s certainly no shortage of power, only speed. The wheel is installed in a rigid steel fork with a torque arm, my aim with the conversion was more about pedal-assist for hills/headwinds with the emphasis on range rather than outright speed or power.
