Hello.
I recently bought 2x makerbase 75100 vesc (already fried one, the bms overcurrent kicked in at 40km/h and the mostfets exploded). I am building dual motor escooter, the front motor is from Kugoo M4, and the rear is from Kaboo Wolf Warrior 11. Installed new wires in motors, and ntc. My problem is when i use the M4 motor, set up 100-120 phase A, it has good torque, accelerating without problems. Understandably the motor overheats at this power, but the controller stays cool. When i plug the warrior motor, run the motor wizard, set phase amps to 120, it has no low end torque(0-10kmh), and the controller overheating like crazy. The motor run smooth and quietly without problems. I bought this warrior motor as used, the coils are clean, without burn marks or rust.
Controller box
M4 motor testrun
Warrior motor testrun
The speed is incorrent in videos, i leaved the 14pole pairs and 83mm diameter setting, because when i set the correct outside diameter its measuring much higher values than real.
Where i should look for the problem? In controller, or can be something wrong with the warrior motor?
I tried different firmwares, sensored and sensorless mode, changed the insulator under the mosfets to silicone pads
Thank you.
Controller box
M4 motor testrun
Thank you.
