Sunder
Well. It's finally happened. I'm admitting I'm wrong. The Q100 328rpm isn't suited for a 700c, 1kw build. Yes, people told me this, but for 4 and a bit months, I sat smug on my 45km/h bike, that cost me loose change.
It lasted me 5 months, but finally, something has broken (most likely the gears or the clutch, given it still works, but now vibrates like something best kept in the bedroom). Given Cheap, Fast and Reliable. I chose cheap and fast, and while I enjoyed it for 5 months, I can't use a bike for a daily commuter if it's going to break randomly every 4-6 months, which is what this build has done. (Last motor also lasted about 6 months, then burned a winding)
So given Cheap, Fast and Reliable, I'm now choosing Fast and Reliable and damn the torpedoes. So, I need your help to help me design my next build.
Budget Excluding Battery - $2000
Hard Limitations - Must use my existing 12S batteries, must use my existing frame
Preferences - Geared rear motor hub, small and silent as possible. 1250W daily, so designed for 1500w+
My first thoughts were:
Bafang SWXH - Oil filled. Buy two. One for immediate use. One to modify for later power upgrades. ($300?)
2kw Sinewave controller (??)
Cycle Analyst ($300?)
Thun Torque Sensor ($350?)
Zipp 808 Rear, 404 Front Carbon Fibre Wheels ($600)
Miscellaneous labour and parts (Wheel building, cover removal tool, spare clutches etc) $200.
That should come close to $2k. If it goes over by a couple hundred, I don't mind as long as there's a reason.
Technical Justifications - If I can somehow program the CA and the Thun sensor to make me move say 2-3km/h before applying any power, then the stress on the gear/clutch should be substantially reduced. Since I want to do some long (70km) high speed (45km/h+), low incline rides, and I want to get fit, then having a Thun sensor can help me manage my power usage, and I can gradually reduce my dependence on the battery.
How would you improve this? I want to order by the end of the week, as the bike is annoying the crap out of me, even though I can keep riding it. I appreciate any input, as this time I will listen to anyone who has proven experience in any of these technologies, rather than try to prove them wrong for a few months
Thanks in advance.
Thanks in advance.
