Sur-ron Battery Extender
johnnyz
⚡ Regular
london,ontario
Hey there...thought I would post some pics, data, video (on Youtube) about my battery extender I am in the final phases of testing.
I looked at the current product available and did not like what I saw so I decided to make my own. I purchased the cells and BMS from a vendor on Alibaba that I have known for 5 years and who I trust. I ordered a couple hundred EVE 18650 cells rated at 2550 and a nice 100 AMP BMS.20210817_073722res.jpg.
I decided to design a case and battery holders to make a 16s 7p arrangement as compact as I could, so as to be as aesthetically pleasing as I could...well..didnt turn out exactly as I planned but will redo as soon as I am able..
Then I 3d printed the case in pieces and the cell holders....20210713_101547res.jpg20210713_101010res.jpg
The 2 reasons I decided on this was because I wanted more range (I was getting about 45-50 kms and less if I maintained 50 kph...also I ordered a BAC 4000 and wanted to up the power level and new from experience that Panasonic PF cells were at best a 10 amp cell and at 135 amps, I was over the design of the cell.
The EVE cells were tested first for capacity20210726_145226res.jpg and the first random 5 cells were all in the 2600 range with resistance of about .035moh...so far so good...
Heres what the pack looked like ready to be welded together...20210725_110417res.jpg
I used Lepage Super glue to glue the pieces of the case together....20210725_120525res.jpg
Now, when putting the pack together, I decided as I had said to weld the packs with nickle strip but on the series connections I soldered a thick piece of 10 gauge solid core copper and then welded this to the next cells in series..20210729_163034res.jpg20210725_111658res.jpg
I soldered 2 of these between the series connections.
This is what the arrangement looked like in the case...20210729_154222res.jpg
I then doubled up the 10 G wire for the Pos and Neg wires...20210729_153256res.jpg
I miscalculated the end of the battery back where the BMS was to reside and the BMS was actually sticking out the end...so I had to make an extension of the original piece to cover where the BMS was20210804_155225res.jpg
I also incorporated the light on the Surron to the back of the case..
Ok..onto to the Surron battery...I did the BMS bypass of the load side myself...
Heres a pic of the case under the seat and mounting points...I tapped the first and last holes and made an aluminum strap to hold the pack...20210718_190634res.jpg
How the pack would have looked...but had to modify the back for extra length and I had to increase the thickness a bit to accomodate everything inside...20210717_151413res.jpg
And the connection to the Surron battery via a parallel connect...20210817_084926res.jpg
There is a lot of tidying up of little things but I wanted to get to the testing so that will come last...heres the bike as it looks with the pack on the back...20210817_091223res.jpg
Since there would be clearance issues I simply put a polyurethane bushing in the shock to limit the travel..20210810_135530res.jpg
Ok...the results...I had Teznic tune the BAC400020210811_155417res.jpg to just under 8000 watts..in this case 8000 watts...Ive increased the range to about 75 kms..thats at 45 kph steady, if I putter around the little village I live in I would get 100 km distance...I have the Cycle Analyst attached and it is showing me under full throttle about 6 volts of sag and most importantly between .035 and .040 moh of resistance...Top speed has increased from 68 KPH to 90 KPH...20210811_122956res.jpgthis is with 2 batteries together which have similar capacity, C rating and resistance...The Surron battery with stock controller sagged 6 volts at 80 amps...it would probably sag around 8 volts at least with this kind of power upgrade, then being over the design limits of the cell.
I have a youtube video of this and am going to include more youtube videos of this bike...(https://youtu.be/rRVPTcCcjpA)
