docw009
🏍️ Giga poster
Short answer is that I could have bought a clone on amazon for 43 bucks for less work. Oh well, I repaired a 5Ah Ryobi tool battery that was ten years old. Every cell was dead at 0V,
On the older OP040 cases, the BMS is hard to remove, soldered to the cells at 13 positions, It did not work when I put on new Eve cells. Maybe overheated during removal or it was already failed. I set the battery aside and it drained all the new cells to zero volts. I think the BMS already had failed.
I ordered a new BMS from China. It's been redesigned, only attached in four spots to the cells, but I had to dremel cavities in the old casing to accomodate it. This time, I put in twenty "new" Samsung 30Q's I had bought in 2021. One cell immediately failed during the first charge and pulled the group to zero. I replaced the group and the pack works now,
The Samsung date code was 2H74 which I was never able to look it up originally in 2021. Google AI tells me it's fake, Makes sense. Never seen cells go bad so quick. Anyway, I will run the Ryobi and see what happens. Am scrapping the remaining cells from this lot.
