srapy said:Thanks Allex, works fine and is much more silent. Runing 11KW on my Surron and it works perfect. I have around 110Hz in the app.
fechter said:What material are the front sprockets made from?
srapy said:Very easy to cut. 110Hz in the Gates Belt drive App. Take a look at the manual then you will understand better. Yes its the mudhugger.
I think its steel.
It sounds a bit like if the belt would jump over under load. Do you feel anything if it appears or is it just something that you hear?Joachim said:The first time i hear this noise was yesterday and i have this on video in the above post @ 1:20 there is the noise....now this noise is always there under a little load and higher speeds.
Joachim said:Put small amount natural grease to the outer side of the belt and the squeak is gone, so the problem in not in the teeth section of the belt but more on the side.
The Hz i have now on the gates app is 80Hz 86Hz 90Hz 83Hz turnt the belt and measured in 4 places.
Run the bike yesterday from a 100% charge to 37% and the squeaking didn,t come back.
I read a lot of comparable issues with belt drive systems on motorcycles/zero bike,s etc..
Joachim said:Just a fingertip natural grease to the side of the belt/pulley edge and the beep sound under load and hi speed
was disappeared.....but for how long?????????
madin88 said:Joachim said:Put small amount natural grease to the outer side of the belt and the squeak is gone, so the problem in not in the teeth section of the belt but more on the side.
I read a lot of comparable issues with belt drive systems on motorcycles/zero bike,s etc..Joachim said:Just a fingertip natural grease to the side of the belt/pulley edge and the beep sound under load and hi speed
That sounds like if the belt would rub way to much on the guide flange which could either come from wrong alignmen, or axial offset.
It would also explain why you noticed the large pulley bends on top under load.
Can you post a photo of the small pulley to see the location of the belt?
Allex said:Looks good, although it is recommended to check the tension on the below part of the belt. What tyres do you use?
So you never added grease on the actual teeth but rather on the high side of them - the outer side where the flange of the big pulley is? Interesting. I try to adjust the belt so it barely touch the rear flange.
dont understand thisAllex said:Shims are not needed. Enough if you just make a quarter turn on the adjusting screws on the swingarm to realign te belt.
Joachim said:dont understand thisAllex said:Shims are not needed. Enough if you just make a quarter turn on the adjusting screws on the swingarm to realign te belt.the compleet rim incl pulley on the back is in perfect line.......there is no way to adjust the pulley..when you do this the rim is not perfect straight in de swingarm anymore including the rear pulley, the belt wil never line up correct. Yes you can forse the belt to one side but the total never line up correct.
:thumb:fechter said:You can easily adjust the angular alignment of the rear using the chain adjusters. You need to use a good straight edge across the rear sprocket that is long enough to reach the front to get a good measurement. Rotate the rear wheel and repeat measurement at several spots.
