freeflow said:Missing part
I'm missing the nut that holds the front wheel, do you think that this is something that I can get from my local bike shop or is it Sur Ron original that is required? Tried to upload picture but I'm lacking the skill.
kitaoka said:freeflow said:Missing part
Which model of forks do you have? RST FaceAce, etc... If you are looking for the RST locking cap I've not seen just that part for sale. Luna does have the whole RST axle for sale which includes the locking cap.
freeflow said:kitaoka said:freeflow said:Missing part
I have the Dnm
I think this have Nothing to do with the controller because the connector on top of the battery give the % signal to the bigger display and also the voltage, so something is wrong on this part from the bms are there is a bad link in from the battery signal plug to the display.fechter said:AlexisSurRon said:I only have one issue:
My instrument randomly shows 0% battery power and 0% voltage. It just flashes/jitters on once in a while, along with the low battery indicator orange warning light, and then goes back to normal. I have the EU above-the-headlight mounted Display (the big one in the center with all the fancy lights).
Once in a while I also get the “Er-002” code on my LCD screen, along with the other orange exclamation mark warning indicator.
The bike itself operates normally though (albeit higher battery drain, but I’m sure that’s normal due to the higher power), no power cutoff, no power limiting, nothing.
The issue seems to be cosmetic if anything.
Does anyone have any idea what might be causing this?
I haven't heard of that one before, but the intermittent nature makes it sound like a loose connections somewhere. Try tracing the cable from the display unit until you reach a connector and unplug it and inspect the pins. One pin may be pushed back or something. Sometimes just unplugging and re plugging can fix things.
Jasonjm said:im riding pretty rocky steep single track on my surron and get flats all the time, even with 203s and kenda tough tubes.
busy installing mousse tires now with no air, anyone else tried this / get flats all the time?
Joachim said:I think this have Nothing to do with the controller because the connector on top of the battery give the % signal to the bigger display and also the voltage, so something is wrong on this part from the bms are there is a bad link in from the battery signal plug to the display.fechter said:AlexisSurRon said:I only have one issue:
I have also a problem on this part: sometimes the % just go from a high percentage to 0% and the volts are stil there...bike keeps wurking perfect,put the battery on the charger 2x and the % reading goes to the level of the soc
Battery seems to be fine...range and power are okey. i have to power up the charger twice and after this the % shows me the real numbers and not 0%AlexisSurRon said:Joachim said:I think this have Nothing to do with the controller because the connector on top of the battery give the % signal to the bigger display and also the voltage, so something is wrong on this part from the bms are there is a bad link in from the battery signal plug to the display.fechter said:AlexisSurRon said:I only have one issue:
Hi Joachim,
How is your battery drain, does everything seem fine there?
What do you mean with putting the battery on the charger 2x?
Joachim said:Battery seems to be fine...range and power are okey. i have to power up the charger twice and after this the % shows me the real numbers and not 0%AlexisSurRon said:Joachim said:I think this have Nothing to do with the controller because the connector on top of the battery give the % signal to the bigger display and also the voltage, so something is wrong on this part from the bms are there is a bad link in from the battery signal plug to the display.fechter said:I haven't heard of that one before, but the intermittent nature makes it sound like a loose connections somewhere. Try tracing the cable from the display unit until you reach a connector and unplug it and inspect the pins. One pin may be pushed back or something. Sometimes just unplugging and re plugging can fix things.
Hi Joachim,
AlexisSurRon said:Aebrennan said:Allex said:Please try to not misinform ppl here if you are not sure about the facts.
The motor(P/N 11100-YQ2A-0200 u can find this label when lifting up the skid plate) has a KTY84 temp sensor installed so the protection is present.
There is so much fake news regarding these bikes i actually stop following it.
Here is the X motor part number
Here is 2 X controllers V2.11 is 8 months old and V2.15 is 5 months old.
FYI The lateset software is V2.19
Pictures do more justice than words.
Hello,
Glad to see so many people interested in the Sur Ron
It’s an amazing little bike.
Regarding the X Controller:
I ordered a Sur-Ron sine wave X controller from Luna (PN: 21100-YQ2A-0301 (another version??), no SW version is shown/scribbled down) and installed it on a german street legal Sur-Ron (the call it the Firefly here) which normally comes with the “stock” controller (PN on that was 21100-YQ2B-0000, SW V1.3.13_2018.11.30).
My motor has PN: 11100-YQ2A-0200.
The positive change in performance is immediately noticeable.
What does that error code mean (couldn’t find any definition to it, also not in the service manual online listing the failure codes)?
On another note, I thought this might be of interest:
On German models removing the slow mode or “unlocking” the bike is done by cutting the green wire.
I still have mine intact, but having installed that X controller, i can now reach 80km/h in sport mode (insane), and on economy it tops out at 50km/h.
Also, I have a connector on the main bike harness for the triangular one coming out of the X controller. I connected them (the Luna Cycle installation video bike does not have this connector), but I have no clue what it’s for. Does anyone know what it is?
Appreciate any help and advice,
Thanks in advance
Joachim said:My custom battery finally ready.
16S-19P Panasonic PF cells/55Ah-3000Wh .
The stock pack drops maximum 5Volts.
The new pack voltagedrop is 2,7Volts.
Today i test the new battery in EP mode al the way full throttle .
took some time to get the battery empty.
ride til 52,7V(2,29V per cell) .
Total range in EP 145km![]()
65/75km in sport mode wil be possible![]()
No not selling these bigger batteries....i test the pack first and maby wil make a compleet plug&play 3,7Kwh battery for the sur-ron in the same aluminium case.AlexisSurRon said:Joachim said:My custom battery finally ready.
Will you be selling them?
As a matter of fact anybody selling 72V batteries in germany?
3DTOPO said:Lelandjt said:What pressures are you guys running in the stock tires for trail riding? My trails are a bit rocky and high speed so I'm around 23 rear, 21 front to avoid pinch flats and squirming. I want to try lower but worried about impacts.
I run around 12psi. With the FOC X Controller, it was tearing the valve stem so I switched to tubeless and haven't looked back.
I wouldn't go below 15psi without switching to tubeless.
have you tried using rim lock?Finer said:I am also running M403's on both my Light Bees (with x controllers). After every 20 miles + trail rides, all four valve stems look like they are ready to rip off. I have been letting the air out, straighten them up and do it all over again. Tried running as high as 15 pounds and it didn't help (also bouncing all over the trail). Rims are clean but the most interesting thing is the direction the valve stems go every time. It's not from acceleration, it's from braking. Guess I'll try to make them tubeless. If it works, I can finally run properly low pressures.
BCTECH said:have you tried using rim lock?Finer said:I am also running M403's on both my Light Bees (with x controllers). After every 20 miles + trail rides, all four valve stems look like they are ready to rip off. I have been letting the air out, straighten them up and do it all over again. Tried running as high as 15 pounds and it didn't help (also bouncing all over the trail). Rims are clean but the most interesting thing is the direction the valve stems go every time. It's not from acceleration, it's from braking. Guess I'll try to make them tubeless. If it works, I can finally run properly low pressures.
Finer said:I agree, I've looked into rimlocks but they are all too big.
