Ohbse
My favorite controller by a mile, the Nucular 24f has recently added the ability to datalog to the onboard microSD card. This allows for some awesome analysis that previously would only be possible with a handful of high end controllers and custom logging solutions or with a lot of external, expensive sensors on a Dyno.
As an example, here's an acceleration run up the moderate hill next to my house. Peak power of 13.4kw, 500a phase, peak of 235a battery on my 16s pack. Battery amps limit was set to 300a here and the pack can support that in a burst.
While the bike isn't slow (remembering this is up a big hill to deliberately load it up more than normal) I am wishing for more area under the curve. Power peaks very sharply and then falls off rapidly. The area that I was immediately drawn to is Motor voltage - beyond a specific RPM this increases very non-linearly. Is this expected behaviour? I've heard the Surron motor is a weird one. This is the limiting factor here in power output - the controller limits motor V to the silicon voltage limit. The no load speed with the same settings here is >130km/h with motor voltage of only 65v
For that same run, here's the graph of some of the FoC parameters over same time period
These logs were taken with 100ms polling intervals, this can be altered to 1ms or even finer, but I haven't done enough tests with this yet. This is a Beta feature and I've already identified one issue with attempting to log at 10ms interval - under acceleration from 0-64km/h with high throttle the log cuts out with 5.9s of skipped data. This happens on the street or on the stand with no load.
Has anybody got any explanation for the behaviour I'm seeing? Is there any specific tests that would be of benefit to run? From 30km/h to 60km/h torque has halved and this is very obvious while riding. If I could extend the usable RPM range of peak torque this bike would be amazing.
