gensem
Expert opinions needed.
Trash it or try to solder it? its aluminium...
johnrobholmes said:Either remake it in steel or trash it. Aluminum braze or solder isn't a good load bearing material.
neptronix said:Sorry to hear this man.. you just got this frame not so long ago, didn't you?
Gordo said:johnrobholmes said:Either remake it in steel or trash it. Aluminum braze or solder isn't a good load bearing material.
You have to remember that "solder" means welding in other languages. Does not matter much as without a molten salt bath, you can't get it back to T-6.
weld in Dutch is lassen, wellen
weld in French is soudez, soudons, soudure, soudent
weld in Italian is saldare
weld in Portuguese is solda
weld in Swedish is svetsa
JEB said:I would do as most likely a temp-fix, remove arm, drill a hole through top, and bottom of the aluminum tube behind the weld (a through hole), maybe in the 1/4" range, use a hard wire (music) .032?~ number of wires to cover around the flat part of the broken arm, about 3/4 ~ of width. (the hole should be about the dia. that the number of wires of the picked size will fit in- 10 wires wide = .320~ wide) a *ring on the top to keep wires straight before spreading out to flat around ring. *(flattned ring), do a tight rap, epoxy, wedge to hold wire tight in hole, bend wire over, more epoxy.
MadRhino said:That frame won't make it, not with the power that you are building. Find a good DH frame to start with. A big, reinforced hydroformed DH racing frame, ideally with dual pivot suspension. Then, even with the best DH frame, never stretch the swingarm to fit a motor, and never solder anything to it.
If you can have a new swingarm for this one, build it low power or sell it.
dogman said:Sadly, it's a start over. But do you bounce well? Got good leathers? If so, Epoxy it with the strongest stuff you have localy, and go try to break it. Nothing better to do while you wait for a new swingarm, or new frame. Gotta find out if your torque arms cut someday anyway right?
Just don't do that if you are an old fart 50 year old with easy to break bones.
kfong said:Any welding to an aluminum frame is usually a bad idea. It just weakens the area making prone to breaking. I know some ES members have done it, but they usually overbuild the area with more structure. Having a frame break on you while trail riding is not something you want to happen. I had a steel frame brake at the stem and was lucky not to get hurt.
MadRhino said:http://www.pinkbike.com/buysell/967535/
This frame is tough as nails for 200$, you don't need a new frame and this one will outlast any Norco
The guy doesn't ship to Brazil, but he had lowered the price twice since he first advertised it
You could easily have it re-shipped by a forum member in Colorado, if you can't negociate the seller
That one is only an example, many DH racing frames can be found for cheap on the west coast of US and Canada.
Even here on the east coast where there are no big mountains, we have a big DH community and the prices drop as much as snow this time of the year.
I did that many times, and the feeling is is the same whether the frame was new or old.gensem said:I ll think about it, but I still wanna be proud breaking a frame.... I mean riding it until it brakes...
gensem said:Expert opinions needed.
Kingfish said:It looks new, that was damaged in some way. Maybe someone set a box on it and it got twisted and snapped. You are done; won't touch it ~ even if you gave it to me free. The one and only way to fix this, and not with my dime, would be to remove the bearing and tig-weld it back with full-penetration. Then re-machine the hole. The cold reality is that there isn't a lot of metal there to support the structure. Think positive: It could be your saving grace cos you've found out now where/how it fails before it could have in a critical moment.
Things like this scare me. Best to steer clear and find something else. :|
Kindred towards your loss, KF
The Cro-motor weights about the same as an X5.dogman said:...I don't have experience with a hubmotor that heavy. 5304 the biggest I've run...
