crossbreak
yeah, at 45kph=28mph like I use to drive with my little bafang SWXH offroad, this looks really different Dont get 50km=31miles with my 555Wh battery at that speed. If I go slower that's no problem, but who wants to drive slow?
Whiplash said:I'm thinking 10ga. Or .100"
bigmoose said:Just wanted to ensure this piece of advice got caught. Welding on aluminum removes all of the heat treatment in the heat affected zone even if done with TIG. For example 6061T6 aluminum alloy has a yield of 40000 psi and a elongation at break of 12%. Dead soft it becomes 6061T0 with a yield of 8000 psi and an elongation at break of 25 to 30%
I have heard of DIY heat treatments, but best bet to a professional that can put the completed frame in his heat treatment furnace.
crossbreak said:Nice to hear that. This way this whole thing sounds way more affordable Which combo does he use, or is it a secret?
DIY heat treatment also sound like worth thinking about... maybe you dont need much more than a torch to get rid of at least some tensile at the weld spots?
this one maybe also interesting for you, the Conway e-rider frame geometry: http://e-rider-shop.de/shop_content.php?coID=10
crossbreak said:Maybe it's not that great idea not to do heat treating :?
I can only sign what bigmoose wrote in the other thread (good reference btw). Even some off the shelf bikes use thicker material than 0.1". But they do not use as MUCH material as you will use on yours I guess, there is a lot of alloy around the battery adding strength to the "box". Maybe you should use some inner stiffeners. Off course it maybe a easier to use thicker material than having to do rework after short time. Heat treatment should not be too expensive, since the temperature needed is relatively for alloy. If you really want to come around this, you should at least do some rough calcs about this. You could just estimate the needed material thickness by comparing with a similar frame, but I guess you wont find any for comparison :?
What sheet material do you wanna use?
crossbreak said:this one maybe also interesting for you, the Conway e-rider frame geometry: http://e-rider-shop.de/shop_content.php?coID=10
For all the reasons already stated.Whiplash said:Why do you say that?
