Just before Christmas I aquired an Actionbent T1 Mesh seat tadpole trike, found here... http://www.actionbent.com/tadpoletrikem.html
I've got a Nine Continent 2805 rear hub motor on the back, with single or dual (in parallel) Ping batteries, 48V 15 Ahr. The trike will cruise in the
high twenties (mph) with around 100 miles of range with the dual packs, if I pedal consistently and easily, averaging around 14 watt hours per mile.
Last weekend I went 59 miles on the trike from Victoria to East Sooke Park on a multi-use path, the Galloping Goose. It can cruise at over
thirty miles per hour on a long flat stretch.
The motor was tricky to install as the dropouts (rear) were alloy, not very deep, and the O.L.D. was 131mm, which required removing mm on each
axle of the 9C to shoehorn it in there with the necessary inner washer. I use two opposed torque arms on each side, to pull the motor up into the dropout,
and immobilize it in both directions. It was a bit tricky to set it all up, but now that it is done, the bike is great. I had to play with the tie rod a fair bit
to dial in the toe-in settings. The trike is a good buy, all alloy frame, with dual disks, and was 1200 Cdn. landed in Victoria, from Redmond Washington.
Possibly one of the cheapest high quality trikes out there, and a great candidate for conversion. The Axiom Journey rack fit well, and I replace the existing
stems to make the handlebars more adjustable and added a Terracycle Sport idler on the chainline. The new idler plugged right into the old idler mount.
I've had the trike up to 43 mph on a steepish but short downhill run of several hundred metres, so it is quite fast, with a rear 26" Big Apple tire,
and front Primo Comet tires (406). I'm using Axiom Dutch Shopper panniers which are great for hauling groceries or camping gear in some of my kayaking dry bags.
I've got a DealExtreme flashlight on the a Minoura Spacegrip on the boom. The trike has the Veloamp from ebikes.ca, with paired Westmarine waterproof six inch
speakers, developing 50 watts per channel - awesome sound, and running off the packs - the amp has a wide input voltage range.
I've got an ideal diode from Nick in England on this site, to parallel the two packs or just use one.
The trike comes with friction shifters instead of indexed - I like the flexibility of the friction shifters. I'm using
a 12 mosfet BMSbattery Universal controller with a standalone CA for speedometer and monitoring energy consumption. Running sensorless, which has
been good - no Halls.
I also have a Sun EZ-sport recumbent, electrified with a Crystalyte 405 but I find myself riding the trike more these days, due to the extra fun factor with the trike.
It is just a bit faster and I like the G forces on turns, which necessitates leaning to the side of turning. The mesh seat is cool in summer, and I've strapped
on a Thermarest on top of the seat, for winter riding, which is nice and warm. All in all, I'm very happy with my new ride.
