Hey Dave.....The tangent is a piece of art, and has already shown to take the 3210/15 torque/power levels very well.
And I'm sure it handle the power of a 3220, eventually with some minor refines for the increased torque/power and the demand of some heavy and/or skilled rider
(solid gears etc.), I'm more focused on how the increasing power affects the reliability/durability of the bicycle drivetrain.
Anyway I would like to get my hands in one soon! and you'll be surprised by the application I have in mind, a true, BIG BIG wheel....
tangentdave said:
The HV80 logging software shows about 0.5V of ripple with the extra Castle capacitors and about 1V ripple without. This includes the extra several feet of battery cable under riding conditions. Castle recommends keeping ripple voltage below 10% of system voltage. This is why I don't add the extra caps anymore.
Yes, using extracap should be a need for some systems, or simply a form of prevention for others, like a general fuse for the batteries.....would be good obviously to have datalogs of these disaster events....and commuting data with many battery models, capacity and chemistry...
Personally I would have both onboard (extracap and fuse) in the event of disasters....
Sure you've played more than me on a comparison among the 80, 120 and 160 versions of the HV ESCs but I can't see the reason to use a 120A instead of a 160A model, with a 3220 4t, costs and a minimal form and weight factor seem very marginal to me. I would feel better running a 120A on a 3210 and a 160A with a 3215 instead
Just to ask: have you guys castle datalogs along the whole discharge cycle, hard driving a 3220, with one of those 14s8p 25r packs?
That would be really, really, interesting.....
As we well know, 25r and 18650 in general have a wider operational voltage range than lipos: a 14s Li-Ion could be discharged at the level of a 12s LiPo starting 8.4V higher (that's one of the contra in any case for Li-Ion batteries on performance machines).
For these reasons, although I have Lipos on my bike, I've used with success for a time a 13s 18650VTC pack .....there where 130 of them (10p) top charged @52.5V (or 4.05V per cell) Not any problem indeed....and virtually it's totally safe (advice from my E.I. RCguru) if your first throttle hit is wide and long enough to consume the juice needed to drop the voltage @50-51V no load, that's the Castle rate......(I.E.a race start or a time attack climb). I've also tested HV lipos that are 4.35 per cell or 52V@12s without any problem.
That said....running 14s, is not sustainable I think.
A >200A continuously capable Lipo pack and an HV 160 are the requisites IMHO for a system that would run the continuous and the peak power levels the 3220 sustains, without constrains, with a safety margin, and with an acceptable performance drop along the DOD (from 55 till 46 kph in my case with lipos, compared to 55 - 39kph with Li-Ions, or, in a 100A CA limited system: from 5000W to 4100W with lipos and from 5000W to 3600W or even less with 18650.
