Ilya
Hello,
I got a problem where it seems like the brake sensor is always triggered in warm weather. The brakes are Promax Lucid (hydraulic). When I start the bike I get a "brake error" that disables engine power (which also occurred previously when I simultaneously happened to press a brake during start). The weird thing is that the error rarely triggers in the morning (which is cold, approx 5C) - or at least it can be corrected easily by pulling the lever completely, while a simple press of the brake in the afternoon (approx 15C) irreversibly, for the remaining part of the day, seems to trigger the sensor.
I don't remember how it got that way, but I did notice that lever gradually lost pressure over a couple of weeks, until there was hardly any resistance left (and no proper brake function). I then proceeded with replacing the mineral oil (pushing from the wheel side up) which with some force applied to it corrected the lever and added good resistance to it. However, once I pressed it fully with the line clamped, it didn't flex back (no apparent leaks). I repeated the process until I gave up and had an initial loose 20 deg of the lever, but at least a working brake. While riding, it corrected itself and provided excellent resistance (which it does in the mornings). In the afternoon I can still press it, but the initial 20 degrees are completely loose until resistance and brake power is felt, then I can't seem to de-trigger the sensor, even if I pull the lever back fully.
I don't know how this specific sensor works, but the problem seems pressure related since the 20-deg loose lever coincides with the error. I have no idea why it seems to be temperature related. Expansion of the plastic is greater than that of the liquid, leaving less pressure? Air bubbles? Sensor readjustment? Any ideas?
