safe
1 GW
- Joined
- Dec 22, 2006
- Messages
- 5,681
The Battery Cell Box Idea
Here's an idea... (that probably has gray hairs :wink: )
You build a box out of something like aluminum. Inside the box you stack an entire set of standard cells of whatever flavor your desire. (NiMh, NiCad, LiFePO4) Then you drill holes in your box and install suspension fittings that will carry the electrical current. The fittings design MIGHT include something like a rubber washer that allows the tip to move a little so that when the battery cell heats and expands it has room to move. The entire thing is then sealed up by closing the box and using long bolts to apply pressure. You could even add little spacers between the cells to allow for air circulation. The wires that extend outside the box would add some resistance, so it would be advised to use a very heavy gauge wire.
This is a variation of the "tubes" concept and allows you to do easy maintenance of your battery pack. You could likely extend the life of your pack if you rotated your cells after starting with a few spares. You would just look for problem cells and swap them out when you find them.
