Mammalian04
Sounds good Mike. Let me know when we are ready to rock and roll with the rear hubs!
Actually, I am pulling CRAZY power (30+ hp) on my Raptor using a standard downhill rear hub and 14 gauge spokes without a problem.LightningRods said:I'm also looking forward to seeing one on a fully assembled bike! It shouldn't be long now.
Settling on a spoke flange diameter was a bit of a crap shoot. I can vary it in the future if there is a good reason to. For one thing, in order to turn down a huge cylinder of 6061 alloy to a reasonable wall thickness on the center hub, there would be a lot of expensive alloy chips on the floor and a lot of lathe time to do it. These flanges are larger in diameter than typical bike flanges, about twice as thick and they have large diameter spoke holes for 10 ga spokes. It may be that they appear smaller in diameter than they are because everything is beefed up.
The stress on the spokes is going to be really low with this swingarm drive compared to a big hub motor. Instead of 20-25 lbs on the axle there will be about 12 lbs near the swingarm pivot. We're using the same 10 ga spokes and 19" motorcycle rim that are used with the big hubbies. We should be good.
LightningRods said:Both drives are completed. I'm having three rear wheel hubs machined right now. Two of them have pre-sold. I made ten swingarm mount drives and have five left. I made five of the bottom bracket drives and have the parts left to build two.
I'd love to buy a Q76R and have a Qulbix of my own. I have three other projects going on at the same time that required buying bikes so I'm stretched thin. I may wait until Spring is a bit closer, clear the other projects and then get one. It's going to be a fun bike and ideal for riding in my area.
The ported Big Block should also be done this week. It's going to be interesting to see how much more power we can push through it with some case ventilation.
recumpence said:Yes Mike, you are 100% correct. Rotational torque is not very hard on spokes. Hammering load due to a heavy Hub motor is what breaks spokes.very few people seem to recognize this on this forum. So I'm glad to know that you brought it up in a clear concise way.
madin88 said:recumpence said:Yes Mike, you are 100% correct. Rotational torque is not very hard on spokes. Hammering load due to a heavy Hub motor is what breaks spokes.very few people seem to recognize this on this forum. So I'm glad to know that you brought it up in a clear concise way.
Yes, the unsprung mass of heavy hubs together with non optimal spoke angle is the reason why they break, but this is a different problem.
What i was talking about is that you could avoid additional stress on the entire wheel when using a hub with larger spoke hole pitch circle diameter.
Matt, you have lets say 300Nm on the rearwheel during hard acceleration (at 30Hp+ and when geared for thrust you will have even more, right?)
the dia of the hub is lets assume 50mm what means the lever will be a bit less than 25mm at 3-cross lacing.
the torque is transmitted to half of the spokes, so 18 spokes.
300000Nmm / 25mm = 12000N
12000N / 18 spokes = + - 660N of tension variation in every single spoke![]()
LightningRods said:Mammalian gave me the green light to mount the mid drive on the 76R frame. Here are some shots of how the new drive fits.
is there any need to quote the WHOLE POST? this makes reading a pita.ElectricGod said:WOW!!! Looks great! This is quite impressive. I think it might be your most compact mid drive yet. Maybe that's just because the qulbix frame is squarish and box like. I really like how the chain tensioner fits in there.
LightningRods said:The small primary sprocket does make the drive seem a lot smaller and tidier. And it fits the Qulbix very well. The frame is just the right shape.
LightningRods said:If you haven't seen the billet rear hub this is what it looks like:
LightningRods said:The mid mount drive turned out really well after over a year of hard work on it. That bike is no longer available so I'm in the process of finding other bikes to install that drive on. I had fun building that one for you!
