agniusm
+1 4 24S 8)
cal3thousand said:Any updates on initial batch shipments?
chvidgov.bc.ca said:It took me a bit of time to figure out how to navigate the interface with the two buttons.
and I shouldn't have any issues doing firmware updates with the additional supplied USB cable, given a few instructions. So far so good.
neptronix said:24S seems to be common enough that not reaching that voltage becomes a deal breaker for many.
justin_le said:neptronix said:24S seems to be common enough that not reaching that voltage becomes a deal breaker for many.
Yup, this message seems to have come through pretty loud and clear guys
We'll make sure at the very least to aim for 100V (or 99.9V) max, rather than the initially planned 95-96V.
bspalteh said:Got one today as well, feels like Christmas! Tried charging a 48/10ah ezee pack, worked fine although it was 80% to start with. Now charging 48v 18ah older nimh pack.
Charger didn't like the thermistor, which is reading 12k at room temperature.
That charger case sure gets hot!
bspalteh said:Now charging 48v 18ah older nimh pack.
parabellum said:Justin, why 24V lower limit? 12V would open huge additional market.
mrbill said:parabellum said:Justin, why 24V lower limit? 12V would open huge additional market.
The specs in the User Manual show that full-charge voltage can be set as low as 12 volts.
parabellum said:mrbill said:parabellum said:Justin, why 24V lower limit? 12V would open huge additional market.
That is cool!
Actually, specs clearly state Output Range 24-60V, 0-8A, 0-360 Watts, somewhere in the manual pages is written 12-60V.
I suppose specs in manual and brochure should be changed then, to not mislead customers.
cal3thousand said:Can anyone that has received the unit confirm the 12V capability?
Would be kind of silly not to allow 12V for SLAs. Not that I don't have a 12V SLA charger, but for road trips in the car, this could be an interesting go-everywhere device.
mrbill said:As one of the few e-bikers still using lowly 24-volt (nominal) batteries (7s LiPo and 8s LiFe), I would like to be able to get the full 360 watts out of the CS (CycleSatiator) on the CC (constant current) cycle when charging my batteries.
Could the maximum output current limit be increased to 12A by a firmware update, or would doing so violate a hardware limit or capability?
justin_le said:mrbill said:As one of the few e-bikers still using lowly 24-volt (nominal) batteries (7s LiPo and 8s LiFe), I would like to be able to get the full 360 watts out of the CS (CycleSatiator) on the CC (constant current) cycle when charging my batteries.
To get a full 360 watts with a 24V battery we'd need different device magnetics meant for a generally lower voltage/higher current output. So for now to make use of the full 360 watts, all you'd need to do is series connect your two batteries into a 48V nominal block for charging
bspalteh said:I'm getting thermistor error on the screen.
