johnrobholmes
It is much more important when you are pushing the controller near the voltage limits. The voltage ripple gets worse when your battery wires are longer, which makes the ESC work harder to keep everything in phase. It occurs on the motor side as well, but I have read that it is more important to keep the ripple down on battery side. When in doubt, just use larger awg wire to compensate. What AWG wire are you currently using?
The owner of Castle has recommended such, but the lengths were probably for a specific controller. I would err on the side of super short battery wire. As voltages increase the battery wire length must become shorter or you must use larger low ESR caps:
If you are running close to the cell count limits of the controller (absolute cell count limits -- not BEC cell count limits) then its easier on the controller to lengthen the motor wires and not the battery wires.
If you are not running close to the cell count limits of the controller, then it is easier on the controller to lengthen the battery wires and not the motor wires.
Try not to exceed 30" of wire on the battery side, or 16" of wire on the motor side, especially if you are running the controller near its limits.
The reason is this: Lengthening the battery wires increases the resistance between the controller and battery, which increases voltage ripple. When running near the controller voltage limits, this additional voltage ripple can break down the FETs, and eventually cause damage to the controller. Lengthening the motor wires increases the resistance between the controller and motor, which makes it more difficult for the controller to accurately commutate the motor, which increases current ripple, which is harder on the FETs. Longer motor wires also increases the amount of radiated noise in the system more than longer battery wires.
Try not to exceed 30" of wire on the battery side, or 16" of wire on the motor side, especially if you are running the controller near its limits. Also, using heavier gauge wire reduces the effect of longer wires. (for example, using 13ga wire in a 30 amp system with long wire runs would be better than the standard 16ga.)
