MattyCiii
A couple of quick pix:
Here's the shiny new 52 tooth chainring. Maybe being silver it'll be slightly more stealthy than the black one? I sure do get a lot of people identifying it as an e-bike, I wish it was a bit more stealthy.
This pic shows the chain line. Above and left of the freewheel you can see the two mounting bolts, and to the left of each of them two black lines. The old freewheel was mounted properly when the bolts lined up with those permanent marker lines - so you can see that the drive is now about 20mm more centered than the old one was.
I have company coming over, so no test ride. I'll be doing the test ride as my morning commute. Worst case - if something is colossally wrong with this setup, I'll just have to remove the chain and pedal all the way to work (8 miles).
