doc007 said:
very cool idea for the gps tracker. does it require a prepaid SIM? Have you tested it out yet?
The tracker is called a
Geogram One from DSS Circuits. I use a SIM from
Telna, inc.
The sim costs $20 a year, has unlimited incoming SMS messages and 1000 SMS per month included in that cost. That to me is essentially unlimited.
The tracker can be put into a deep sleep (extend battery life). In deep sleep, the GPS and cellular radio are off. That's the trade-off. Tracker features include lots of great things: motion sensor and LiPo state-of-charge awareness. Here's how I plan to use it:
Normal operations: Set the device to do nothing but sleep all day, waking for a minute every 2, 4 or 6 hours to check in to the cellular network. Any pending SMS messages will be received by the device. Go back to sleep, repeat. This maximizes battery life. It can run a fortnight like this without recharge, so if I charge it once a week, I always have at least 7 days of life if it's stolen. If I get lazy with the recharges, it will send me a "low battery" warning the first time it wakes and sees less than 30% charge. Oh, and I might be able to fit in twice as much battery and have 1 month of battery life (awaiting first set of batteries to see).
Bike is stolen: With the device asleep, all I can do is send it some commands via SMS and wait for it to wake/check-in. Once awake I can send it commands to have it tell me it's location right away. But if the bike is in a basement, I'll get 00-00 x 000-00 as a location. If that happens, I can put it back into deep sleep mode, but with a motion sense override. It'll thus send me a new position within a minute of being moved (has to get a GPS fix). At that point it's a judgment call what to do. If the position is still 00 x 00, I'll have to decide whether to put it back to sleep and wake on motion, or have it just plain sleep, to balance between finite battery life and getting a position.
Pro's and con's:
Pro's: On the plus side, it's got a lot of features and is very small. The GPS and cellular signals pass through the aluminum emclosure well enough to work when above ground. It's open source and programmable - I should be able to add features such as a microphone such that I call the device and listen in on the bike thief before or as the cops come knocking on their door.
Con's: On the con side, deep sleep still draws a lot of power because the microcontroller is counting seconds for the sleep timer. There's chatter in the Geogram One forum to work in a deeper sleep mode. Sleep/wake timing becomes less precise, but life in deep sleep mode becomes so much longer. Also, the GPS antenna is right on its chip - no chance for an external GPS to improve likelihood of a basement position fix. The cell module has an external antenna.
