safe
1 GW
- Joined
- Dec 22, 2006
- Messages
- 5,681
Revised Results
Okay the "revised" numbers are now:
First Gear: 0-15 mph in 2.16 seconds with an energy "cost" of 3 kiloWatts. (3,219 Watts) (0.06% of a 1440 Watt/Hour Pack)
Fifth Gear: 0-15 mph in 3.25 seconds with an energy "cost" of 4 kiloWatts. (4,367 Watts) (0.08% of a 1440 Watt/Hour Pack)
The net "waste" for the "hub motor" gearing is 1147 Watts or an excess waste of power to the tune of 36%. (same as before more or less)
Note: I was trying to use the torque figures and it's just much easier to go directly off the Power(in) and Power(out) values. The proportions are the same and now the numbers for seconds are more realistic. The power is also more realistic. This one acceleration would equal a "waste" of 0.02% of the power supply of a 1440 Watt hour battery for this 1200 Watt motor at a 60 amp current limit if it was run in fifth gear rather than first.
You also "lose" 1.088 seconds in acceleration. It's both SLOWER and more WASTEFUL.
