Ianhill
- Joined
- Sep 25, 2015
- Messages
- 2,918
A very interestng thing is the Haarp facility which has a few facts hidden among many conspiracy's, One fact is that lighting occurs many times a second all over the planet and our ionosphere stays positively charged shocking the ground we stand on I guess its due to solar wind Interaction it stays positively charged so blasting a ionized beam straight up to create a low resistance path back down can give a massive flow of energy back towards earth a way of getting over unity more energy back than whats put in for REAL no tricks.
Tesla experimented with this but could not control the back emf and blew his transformers with a bolt of lighting grounding through his windings, The US kept his patents after his death and released the ones of little use as they normally do. But I believe the haarp array is a sound way of defocusing the energy coming back down from a pin point like lightning to many metres wide and then the whole area captures the reverse energy through its antenna 5gw up over many antennas to make a grounding point for upto 100gw back down split over many antennas more energy in over more antennas bigger the grounding path and more energy back down, rather than teslas one transformer winding that would have give an almighty flash as around 100gw melted it like a capacitive discharge BOOM.
A way to control lightning and to see how fast the ionosphere recharges from solar and atmospheric effects is what this facilities hidden agenda has always been in my opinion its not hidding planes out of thin air thats conspiracy whack invented by themselfs throw you off the trail, I dont know if its causing earthquakes but its fesable it can control the weather (though its not like turn the rain on/off it just releases heat into the atomshpere). It can be used for defense and ears dropping its a swiss arm knife in disguise.
Thing is this machine may be having a lot of negative effects on us, one being high energy storms more often and stronger will be seen but its been turned back on 2017 LOOK OUT.
