nutspecial said:
Would battery/controller tech be adaptable to the subsequent possibilities of higher volts and less amps, and what kind of numbers would they be: like 900v and 7a instead of 90v x 70a? What would be a reason and what conceptually is the limit in that direction of thinking?
I have a few for you:
1. You would die before you finished building it.
2. If you were resuscitated successfully, you wouldn't be again after you rode it in the rain. (unless you decided to dedicate at least 10x the engineering time and resources as the pack costs to make something that can actually function in a condensing humidity environment at 900v and do more than burn down in a week).
3. Corona just naturally streams off any sharp geometric points once field strength gets high enough. Corona + time breaks down most things known to man.
4. You would already be dead by this point, but your BMS management harness and cell stack chips would be close to the weight of your pack, and much more cost than the cells if you used something that's not just a fire-waiting-on-a-pcb-at-900v BMS.
5. Your controller would require SiCFETs (to be efficient) that would cost more for 6 of them than most ebike hubmotors+ controllers cost, or run IGBT's and eat a series diode drop loss of ~1.4-1.7v x 2 per phase (roughly like throwing one of your series cells away in heating the controller pointlessly).
6. Your motor would stream corona for a bit before arc flashing through your winding enamel in some invisibly defected area from winding it. If you re-wound it with the right rating of wire and didn't so much as chaffe through it anywhere, it would still be a very meaningful copper-fill and ultimately continuous torque and continous power penalty from such a greater percentage of the slots area being varnish rather than copper.
7. At least a few of us would miss your very open minded posts here, due to reason #1, and best case #2.
ATB,
-Luke
