rf said:
Just came across this item at All Electronics ...
A 5-volt 3.7amp `wall wart' switching power supply.
http://tinyurl.com/2vlkdf
I found the jackpot: 3.3V +/-10%adjustable =3.63V at 8A switching for 12$ :wink:
http://www.web-tronics.com/253siouposup.html
Complies with RoHS Directive
AC Input Voltage Range: 85-264VAC (120-370VDC)
Input Frequency: 47-63Hz
Inrush Current: Cold Start, 20A/115V, 40A/230V
Input Leakage Current: <0.7mA/230V
Line Regulation (Full Load): <± 0.5%
Output Voltage Adj. Range: ± 10%
Output Overload Protection: 110-150%
Output Over Voltage Protection: 115-150%
Withstand Voltage: I/P-O/P: 3.0KVAC/1min; I/P-F/G: 1.5KVAC/1min; O/P-F/G: 0.5KVAC/1min
Rise Time: 50ms@full load (typical)
Hold Up Time: 20ms@full load (typical)
Operating temp.& humidity: -10°C to 50°C (14°F - 122°F), 20%-93%RH (non-condensing)
Storage temp.& humidity: -20°C to 85°C (-4°F - 185°F), 20%-93%RH (non-condensing)
UL Ref. Number: E258719
Safety Standards: GB4943, UL80950, EN60950
EMC Standards: GB9254, EN55022 classB, EN55024, EN61000-3-2,3, EN61000-4-2,3,4,5,6,8,11
Cooling Method: Convection
Dimensions: 3.94 x 3.28 x 1.4"
The best we can find i think!
1+ $14.90ea.
10+ $12.60ea.
100+ $10.78ea
8A at a great 3.63V would be perfect to charge a:
- 1p pack in 15min
- 4p pack in an hour
140$ for a 288Watts 10s 36V charger that charge 8A !!
Doc
