GreenRoad
Stielz said:Thanks for your reply.
I brought the Max-E so fingers crossed that I can get it working well with the C80100 130kv stock wind and then with a custom wind for lower kv.
Might need to pick your brain when my controller arrives to better understand what settings I need to adjust..
no problem - for that we are here....
Iam also interested if your motor works. The secret are the settings, autoset did not work at my motor, also not verry well at the Bafang middle drive. But it should work if you have the right settings.
It good to use an "normal" controller for the testing - like Kelly or Lyn.
This was also my first step, to be sure that the motor works well.
But with the debug screen on adaptto you could also easy find out if something is wrong, like damage hallsensor ....
The important thing to proof the settings, is to look on the temperature of the controller. In my case the motor spin, but the controller gets warm under load - the motor was still okay.
I think if more people play with outrunners, adaptto will also improve the autosettings.
But this is one big difference between normal controller an an sine-wave controller. The controller only works well- if you have the right settings. With an normal controller it should always turn....
