Hi, I recently purchased a 15kw Alibaba stealth bomber and while looking for a switched 72v power source for some accessory off road lights I think I triggered some sort of anti theft setting. I opened a 30a cylinder fuse holder and the moment I snapped it closed again the back hub motor beeped several times and now no longer moves when I twist the throttle. When powered on everything else is working except for the hub motor. When that fuse is pulled the bike does not turn on so I believe that is the 72v source for the controller to switch on. Any thoughts on how to reset this? The controller is a Fardriver 72270 and everything was working fine until I touched this fuse which is still intact.
