Lithium is hazardous. We can apply proper charge-discharge procedures to prevent fire, but it is not 100% secure. What kind of protection is required to ensure that lithium fire will not endanger anything outside the battery pack that is built into a bike or other vehicle?
Specifically I'm interested in what would happen if an approx. 2kWh lipo or other lithium battery ignites in a closed metal box, like a Stealth or Qulbix or Vector bike frame, and I prefer to discuss instead of trying.
Some outcomes I think of, but not sure which one is probable:
- can high enough internal pressure develop that frame explodes? Is the high pressure a realistic problem?
- the frame heats up very much and combustible materials outside the frame ignite, starting from the plastic paint of the frame, then the other parts around?
- can the frame melt (aluminum or steel) due to concentrated heat, then fire gets out of the box?
- the small amount of air getting inside the frame through the slots (e.g. charger connector) is enough to maintain the fire inside and the flames get out?
- fire is extinguished in the absence of oxygen, there is just some heating up and the outside temperature remains relatively safe, e.g. below 100°C?
What is the realistic scenario?
What would be the safe protection? For example non-flammable or thermally insulated casing of the pack with a pressure-sensitive valve outlet would be needed?
