This is inexpensive, but not remote.
https://www.ebay.com/itm/150A-High-Precision-RC-Watt-Gauge-Power-Analyzer-Battery-Voltage-Amp-Meter-RC774/312666146207?epid=4019700605&hash=item48cc5ac59f:g:7moAAOSwyvtdDFw3
THE THING IS THAT I WANT TO AVOID LONG HANGING WIRES HANGING OF MY PACK BOTH BECAUSE IT IS COMBERSOME AND COST MORE GAGE 10 WIRE. I IMAGINE THAT MY CHARCHING CONNECTOR CAN BE GLUED ON MY PACK AND IT WOULD BE THE CHARGER S CABLE THAT WOULD BE REACHINGG TO IT? CAN I DO THE SAME FOR THE MOTOR CONNECTOR LIKE IT WOULD BE GLUED ON MY PACK AND JUST CONNECT IT WHEN USING IT? I DONT KNOW WHERE TO PLACE THE CONTROLER. IS THIS A WATERPROOF THING WITHOUT DISPLAY ON IT? OR I HAVE TO PLACE IT ON MY HANDLE BAR.USING KT CONTROLER.
What you are looking for is a cycle analyst to show temperature/voltage/current but they aren't cheap. see www.ebikes.ca
THIS DEVICE SEEMS USEFULL BUT IT DOES NOT SHOW TEMPERATURE. CYCLE ANALYST IS TO EXPENSIVE. IS THERE A TEMPERATURE GADGET THAT I CAN PLACE INSIDE THE PACK THAT IS CHEAP?
And on the question of where to Y, it's a hard to determine what you are asking for due to a confusing drawing and language translations. As a rule of thumb, you want the wires between the battery and the controller to be a short and thick as possible. Charge wires can be longer and thinner. Also, many BMS's now include a temperature probe that will shut make it shut off the power if the temperature gets too high. THE BMS I USE IS THIS ONE CAN YOU TELL IF IT HAS A TEMPERATURE PROBE IN IT ? IT WILL BE GLUES ON THE PACK DIRECTLY INSIDE HEAT SHRINK
https://www.aliexpress.com/item/Deligreen-13S-18A25A35A45A60A-48V-PCM-PCB-BMS-for-3-7V-lithium-battery-pack-18650-Lithion-LiNCM/32888880741.html?spm=a2g0s.9042311.0.0.27424c4dp9h0s2
If that doesn't help can you rephrase your question?
