mwkeefer
nutz,
This would work... I have succeeded in running a 9c hub without sensors using an HV110 with huge caps and a 4" power cable run... startup was a bit odd at first but it turned out to be an issue with my PWM throttle interface... I wasn't doing enough range for it so I opened it from .5ms to 2ms as the standard says it should be and whalla.... SLAMMING STARTS no sensors.
On the contrary I have used sensor based infineons with BLDC Outrunners modified with halls.
The halls are only needed in massive power applications where 1/10th seconds (maybe 1 second) matters... for most it just doesn't.
The back EMF zero cross algorythim isn't too difficult to implement, I have a little Atmega 1280 here running a very low power BLDC controller... currently sensorless only but I will be integrating sensor management then I will scale the FET board (seperate from the logic board)... I have to make a design change in my existing FET drivers since to acheive 160v I will need to use FETs with nearly 2x the turn on resistance as the IRF4110 FETs everyone is using for 110v... I want to eventually offer a very modular design as robust as the Kelly but small like the HV110, not an easy TASK but.... if you reverse engineer infineon controllers you can see that they would adapt reasonable well to a multi layered double thick PCB using smt components. We could cut the size of a 9fet regen unit by 50-60% and at the same time solve the issues of tracebeefing and such by designing the PCBs to support the higher amperages.
Okay... way off topic. sorry.
-Mike
-Mike
