ZapPat
My hall effect throttle wire got cut the other day, and this resulted in the sensor chip being destroyed. I searched here on the forum, and even on google with not much luck finding repair info on hall throttle repair. Since I don't like to throw stuff out that can be used or repaired, I took the throttle apart and checked out the chip being used. I figured this might interest other people so I decided to post this about replacing the hall element...
Please note that the hall sensors used in throttles are not the same as the ones used in brushless motors, since the ones in throttles need to have a linear (continous) response to magnetic fields.
The number I found on the hall in my throttle is 3503, and a quick search revealed that this is an Allegro 3503 linear hall sensor, but is now discontinued. The replacement part is the Allegro A1302, and costs only 1.44$ canadian at digikey (Allegro A1302) - better than 20 bucks or so for a new thottle!
I will order the replacement and post my results here in a week or so when I get the part.
