Tincan
Gents,
It's come time to get some Lipo on the scooter.
Currently using 8 x 12v 7ah lead.
I have spend the past week now reading over nearly every topic i can find on the matter and have built what i believe will work for what i need.
Essentially I need to have a setup that i can plug the mains into, have the chargers on board and take care of the rest (still checking things on occasions)
I have used
http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=14694
Turnigy 5000mah 22.2v 40c for power
and
two http://www.hobbycity.com/hobbycity/store/uh_viewitem.asp?idproduct=10327
Hobbyking Quattro 4x6 for charging.
I'm going to build a 133.2v 5ah pack to start off with. My commute to work is rather short. The CA tells me i pull about 1.3ah from the current setup on my trip.
I do however want to build on it in stages, giving me in the end 20ah to essentially go for a rather long ride.
One of the main stipulations is the need to be have it configured and left configured without the need to plug and unplug things when it comes time to recharge / discharge. This is due to the battery locations on the scooter and where i will place the chargers.
This is what i have in mind for the original setup.
Rather simple, one battery per port, balance wires plugged into each port, giving me one port spare on each charger. I will be using these for something else down the track, so they wont be wasted.
As i go, i will add onto this, like so.
Essentially just running the additional packs in parallel.
Can anyone see potential issues with this setup?
I have used
and
