steveo
Hey Everyone,
I was wondering if i could get some help, I'm looking to build some pcbs adapter boards that will allow the user to use a Infinion 12 mosfet or 18 mosfet Board that regularly uses to-220 mosfets & adapt to-247 mosfets to it.
I remember a while back, there are some websites where you can send some sort of image where they can design a pcb, does anyone know what i'm referring too?
I've found a way to run the vr cirucit only off of 15v max** battery, ( i use a 3s lipo & try to keep it fully charged), I will post a pic on this easy mod soon!..
By doing so, it allows you to safely run a higher voltage to your caps & mosfets, the goal hear is to build a reliable 150v controller ( all ways use a precharge resistor for 100v+ ) i use a 1k 5w resistor with my ev200 contactor.
I will be going with the irfp4568 mosfets, discussed in another thread to be a good choice for the project.
some of you may remember an old thread with my first attempt of 133v which i was successful with my x5304 motor at 50amps...
Hear is a picture of that same controller but the pcb replaced with the new infinion programmable board.
thanks
-steveo
thanks
-steveo
