Torque Arm for Sturmey Archer IGH?
howlndog
100 µW
Winnipeg
I've recently installed a Sturmey Archer internally geared hub. The performance has been terrific... for the first minute, then this happens.
Any suggestions on a suitable torque arm (or remedy) would be appreciated.
Derek
spinningmagnets said:
Could you post a pic of how much axle is available to attach something to? A pic would also show any parts nearby that might conflict with a DIY torque-arm.
I can't tell for sure from the picture, but does it look to anyone else that the axle is too small for the fork end? If it was, no wonder you broke the bolt.
But like I said, I can't see enough to be sure that's the case.
You could order something to be water-jetted, or laser-cut. If making a torque-arm yourself, I have found its "easy enough" to hacksaw cut aluminum, or maybe use a thin abrasive wheel on an angle-grinder to shape a steel plate? (Wear eye protection) Drill a hole where the axle will go in the plate, then cut a slot out
You might find some ideas in the big torque arm thread:
https://endless-sphere.com/forums/viewtopic.php?f=2&t=26444
I would make 2 torque plates . On the right side, I would make it one piece integrating the tensioner hanger. On the left, I would make it to attach to the brake mount.
I don't know the size of your drop outs. but most IGHs axles are smaller than the many drop outs. Perhaps they've opened up as well?!
Check out these adapters towards the bottom of the page, might help in coming up with a solution. All these designs are for a Yuba Mundo, but you'll get the idea.
http://yubabikes.com/product-category/parts
Most axles are 9 or 10mm (or their equivalent imperial size). I suspect most parts manufacturers make them just universally in 9mm size, so that they fit perfectly in 9mm dropouts, and are "close enough" for 10mm dropouts.
Recently, I've heard about 12, 15 and 20mm dropouts for mountain bikes for increased strength and stiffness. There's no way that a 9mm axle won't spin out in there.
Any torque arm you install in a case like that, is just going to be masking the problem - and I suspect not all that well.
Probably best to get an adaptor as Mundo mentioned, or get the right sized IGH.
Hillhater said:
Why would an IGH need a torque arm ?
Its torque reaction is against the chain ..
And against the frame via the axle, depending on what gear it's in.
http://www.sheldonbrown.com/twist-internal.html
(interestingly, the pic the OP used is not of his own parts, but is actually a link to the picture on the page above)
