TOSEVEN LCD135C (DM01) display manual
Astropower
Israel
Hello folks,
I got two TOSEVEN DM01 1000W 52V, with LCD135C display.
In order to serve the community, i am posting here the manual of TOSEVEN LCD135C Display manual. Which sent by the Factory.
The factory did not write in the LCD135C manual, how to get in the Advance Menu and FOC Menu, so i took it from the T24 manual, and put it together in one file.
And Firmware update for this display, from 21/06/2024
Instructions how to program:
  • LCD135C USER MANUAL.pdf
  • TO7-LCD135C-Y240621A.zip
Hello folks,
did the instructions for the advance menu from the t24 work on the lcd135? i can get the normal menu but not the advance
Hello folks,
Thanks so much for posting your LCD135 manual. The "Meter Wiring Definition" has been helpful. My new DM02 with LCD135 does not work; I press the power button on the LCD135 "Operator", and nothing happens. To make sure I was getting power to the LCD135 through the DM02 I measured voltages on the connector pins on the back of the LCD135. I got 56 Volts (same as the battery) between "Bit # 1" and "Bit # 2" on the J4 connection marked "OP" (which came with the pushbutton switch connector inserted). Your manual does not show voltage on any of the J4 pins but to me it is an indication that there are connections between the battery and the DM02 and between the DM02 and the LCD135. I do not get 5 volts as shown in the manual on the J1, J2 or J3 pins, possibly because it is not on. Although 56 Volts indicates there are connections, could 56 Volts an indication of a short circuit somewhere?
Thank you for the manuals. I was just looking for them in PDF format. Unfortunately, as it turns out, PDF files only open on my phone. So, in order to access the saved files, I had to use the SVG to JPG Converter pdfguru.com/svg-to-jpg which I use for my studies. I was able to convert them into another format, and I’m really glad that I managed to keep all these manuals in a working state. If someone had a similar problem, I think this is a good solution.
