Jayw900 said:
Might be an odd question but how are the wheels held on for a trike or 4 wheeled bike?
There are quite a few ways, depending on the design of the trike, and what kind of drivetrain it uses.
Some are double-ended axles, some are single-ended.
Some use flatted axle holes (or something similar) that locks the wheel to the axle) and a live axle or other driveshaft to the wheel, so that the drivetrain can drive the wheel directly thru the axle. (methods of driving the axle vary as well).
Some use wheels with round axle holes on bearings just like regular bike wheels, and some form of washer/spacer on the axle and a nut or pin on the end of the axle to keep the wheel on, but the wheel rolls on the axle and is not driven at all.
Some use the above method except they use "rear" wheels with drive sprockets, and use a chain drive to the wheel.
Some use hubmotors, with either single or doulbe ended axles. Mine uses two regular MXUS 450x hubmotors on the rear, and a regular bike wheel up front for now. My brother's trike uses three regular bike wheels (now with two geared hubmotors in the rear instead), wiht the rear wheels tilted at an angle to give a wider track (stability) without making the trike quite as wide as with vertical wheels.
Some use regular hubs with bolt on wheels lke cars, trucks, etc., although they are usually much smaller and ligther hubs and wheels.
Etc.
Lots of ways to do it.
I recommend looking at images of various trikes, and trike wheels, like in this search
https://www.google.com/search?q=trike+wheels+-motorcycle+-drift&btnG=Search&newwindow=1&client=firefox-b-1&tbm=isch
Or other similar searches.
Also look around at the build threads of variosu types of trike here on ES (and elsewhere), like my SB Cruiser and Raine Trike threads, or the various KMX trikes and various custom builds, delta trikes, tadpole trikes, etc.
I was thinking doing drop downs but instead of them perpendicular to the road making them parallel.
What does "drop downs" mean?
