This would be my first build.
You list that you are living in the UK. Consider if you'll be riding on the public road, and whether there are any restrictions on the paths off-road you'll be riding on. I know there are restrictions on mountain bike riding in some places - something like that may be relevant.
When you've worked out the speed range you want, you might use the Grin simulator to explore what you need to provide that. I find one Leaf motor in the list, and if you want to explore further there is an option to enter motor parameters to match others:
Leaf motor in Grim Simulator
Apart from the motor, think about maximising the battery - assuming a Lithium-ion chemistry. The battery is often the most expensive component, and by sizing the battery so that you only need to use about 2/3 of the maximum capacity, it can last for at least 3 times the kilometers, while also staying in it's safest state. This comes from never letting the charge go below 20% and charging only to 80%-85% at the top. Also, only buy batteries made with new, name brand cells - Panasonic, Sony, Samsung, LG. The economics work out, and you'll minimize the chances of fire danger. You'll want to factor this into the economic decisions.
There are good components available that can handle rain. I think you want this - a failure could be very inconvenient.
