winkinatcha
bunch of potential causes,
current symptoms:
Throttle works intermittently, and seems to cut out and stay cut out when WOT is applied
Pedelec input intermittent, but better than throttle... that is, when engaged, consistent cadence produces on-off-on-off power sensation, maybe half a second on, then off for unpredictable time.
(when working correctly pedelec produces similar sensation to WOT... consistant uninterupted power.)
History:
Existing Vintage road racer build, running mini geared hubmotor rear.
bog standard Cohnis kit 9 FET controller 20-25 amp, 62 volt caps.. presumed 75v FETS, modified to 10-15 amp by removing one of two shunts
Controller has been run and is capable of being run at voltages from 24 thru to 60
thumb type throttle shell physically modified but electronics untouched (hall sensor and magnet)
pedelec ring sensor on Bottom bracket, with plastic 6 magnet ring on axle inside crank.
(mmm think I just figured where I need to check... Pedelec sensors have been a "challenge" in the past on other builds)
Build was initially working absolutely fine and dandy, running 12s LiPo, nominal 500w, through a 36v QT120 equivalent style min-geared-hubmoter
Motor is Nominal 250w but seemingly more than capable at 750w for a road oriented build.
I broke the first motor, literally by accidentally jamming a huffy drift trike into the back wheel at 25km/h
I just got some new stock, different manufacturer, mini geared hubmotors, nominal 24v... meaning fast wind...
I installed one of these wheels into the existing build, swapping out the busted 36v wheel, Saturday night, preparatory to a group ride here in Melbourne AUS on Sunday.
Got lost getting to the ride Sunday AM and ended up riding the bike hard, a fair amount of road work, lots of WOT or full pedelec, CA saying system is drawing around 600 watts maxed out.
GOOD SPEED, hit 50km/h with the motor still pulling on the flat.
Found the group ride, just as I killed my 12s LiPo battery... (Next minute... 12s pack is reading 30v
Holy Carp.. I just killed my battteries.)
Borrowed a 58v pack...
Wass following a mad down-hill local (Full-Throttle) and inadvertantly found myself launching my roadie and belting into a few things, including the ground, though managing to stay upright.
got onto som clean bitumen cycle track and managed to wind the bike out to 55
caught up with group, lots of full throttle and hardcore abuse, including attempting a hill-climb and stalling out...
Began to have "throttle issues" as above
Got a lift back with bike in mates trailer
swapped battery for a 36v monster and went for a 50 km ride this AM
throttle issues initially not bad but worse and worse til eventually rode final 15 odd KMs on pedal power.. (Advantage of lightish road build... not a total shit-fight to pedal back home
After writing this... the first thing I am gonna do is swap out the pedelec sensor, and see if that makes a difference... Had issues with them in the past... may have got bashed on the trails...
If swapping out sensor makes no diff, will take off all electrics and put in a box marked "WTF?" and install new stuff... I did give the poor thing a hell of a hard time and hard to track issues like water ingress (went through a few puddles n a little mud) as well as a bunch of other stuff could mean stuff well beyond my current knowledge of testing n repair.
But if anyone's got another idea about what might be causing these throttle/pedelec issues... (maybe not even the controlls but other stuff going on, like internal shorting in the hub or summink...)
It would be awesome to get your input
mmm wonder if I have smoked the motor... ohhh and it's not halls... when the motor runs it is smooth.
Cheers
Joe
current symptoms:
History:
Cheers
Joe
