e.mote
Hi, I'm an ebike noob trying to fix my brother's ebike, and am looking for some help troubleshooting.
The bike is an Ancheer from Amazon, bought a few years ago. AFAICT, it's a fairly generic bike. 500W rear hub motor (no brand). 36V-18A-450Wh Chinese batt pack.
The trouble started when the rear wheel popped out of the axle, probably because I hadn't tightened it down enough after replace the brake pads. It stretched the motor wiring harness and broke the housing, seen below,
After putting the wheel back in, the PAS stopped working (throttle still works to spin the wheel).
Being a noob, my first instinct was that the wiring damage may have extended to inside the motor. As it happens, we do have a brand-new identical spare motor on-hand, with an undamaged harness, so I swapped out old motor with new motor, keeping the old motor housing of course. Sadly, the PAS still isn't working.
This is the PAS sensor,
Troubleshooting:
. Checked for mechanical wiring & connector breakage, including inside motor controller.
. Checked for physical damage to PAS sensor (none). Cleaned PAS sensor.
. Disconnected both brake sensors to test PAS.
. Disconnected throttle to test PAS.
. Get reading from PAS sensor: from signal pin to gnd is a constant 3V, from power to gnd is a constant 4V. This doesn't seem to change when turning the cranks (and sensor).
All indications tell me that it's a bad sensor, as from what little I know, the signal pin should cycle between 0V to whatever V when the sensor rotates. But I don't know how it could turn bad from a yank on the wiring harness?
This is my first time troubleshooting an ebike, and I have no experience with it, and am hoping the veterans here can lend a hand. So is there anything I'm missing? Is it a straightforward matter of replacing the sensor with this?
https://amazon.com/dp/B07VDQ3GL4
Any suggest or advice would be much appreciated.
PS: This is actually a good experience for me, as I'm working up the motivation to do a DIY ebike conversion, and get my fat ass back on the saddle once more.
Thanks again for any help.
Troubleshooting:
