ccmdr
Sunday night syndrome kicked in and what crossed my mind 'Cycle Life' and getting that real world Ah usage from a battery/pack.
There is alot of information on 80% 'Depth Of Discharge' (DOD) vs extending cycle life, but how are you measuring yours?
I'm no expert and could get some of this wrong, so please correct me if so
Now for the question. This is for all cells, but I'll use my pack for a real world relation.
Say you have a 20Ah LiFePO4 pack and the manufacture recommended spec is:
Max charge Voltage 3.65v
Min Voltage 2.5v
So they 'claim' from the battery being fully charged to discharge it will output 20Ah at a specific Discharge rating, for this example 1C. We now want to extend the service life of our expensive batteries and have seen 80% DOD can extend Cycle Life. But looking at a standard Lithium discharge gragh we all know about the 'Cliff' where going below a certain voltage gives you diminishing returns at a sacrifice of cycle life.
The standard smooth Discharge graphs give a representation of voltage and amps used over time. Unlike some of the sawtooth gratphs when the cell is loaded and unloaded.
Background covered, if you were to discharge at higher C rates loaded vdroop becomes more apparent. This is where I'm getting lost, wanting 80% DOD your minimum voltage would be around the 2.7-3v, however this would have to be a 'loaded' voltage due to the resting voltage bounce-back. Running 2-3C the discharge rates the voltage drops below your 80% DOD voltage of 2.7-3v.
80% DOD is can measured by loaded voltage, but depending on discharge rate you can exceed it in a very short amount of time. 80% can be 16Ah, but realistically your taking from the top and bottom from the discharge curve so you'd lose more capacity from the top. Now take into consideration temperature and the vdroop involved with 10C or 0C ambient. Even on a mild discharge of 2C you'd be close to exceeding 80%.
This must mean anyone running a mild C discharge rating is already exceeding 80% DOD right?
With the Adaptto BMS you can set the voltage exactly for 80% DOD, but I find it frequently cuts out due to vdroop under load, so I can never truely keep the battery cycling at 80% DOD. Anyone else experience this?
Min Voltage 2.5v
