Ianhill
- Joined
- Sep 25, 2015
- Messages
- 2,873
Yes bldc are frequency controlled, the voltage caps the peak of the sinusoidal wave and there has to be enough capacitance in the circuit so the current does not lag the voltage by too much as thats where bad efficency starts to happen such as the fets case will be passing alot of current as heat.
Its the current in the circuit that will lock the rotor to the voltage sinusoidal wave as theres increased load on the motor the current must rise to keep the lock or a bad power factor can occur which is alot of heat created some where with poor efficency and worse case a stall can occur.
A motors stall current is always low at that point theres no rpm as the motor turns it builds up a back emf that opposes the current your trying to push.
So a stalling motor will want to pull alot of current but its limited in its ablity to oppose it or cool itself but a high spinning rpm motor we will want to push more current at it but the back emf will be too strong and limited the current.
Thats how dc motors worked off a battery with no controllers in the early days just a variable resistor to limit the rpm exactly like the analog scalextric systems but over time mosfets have taken over then we had pwm signals and full h bridge motor drives
Induction motors are frequency driven too so the controller advancments led to bldc been implemented i think but all that happened before i was born so jits obsolete and a cars inverter setup is where its at all the setup in that is whats needed to be understood.
Alio and his build threads offer loads of interesting stuff on mosfet ringing and lots of hidden gems to show that in reality a cintroller is best tuned to its motor like a speaker and its crossover without over spec redundancy built into it.
Theres been many a vesc thread thats ended with problamitc results even for circuit based engineers.
