Hello
I have a tsdz 2 with 6 pin vldc5 from Enerprof (probably after 2020 version) without speed sensor connected.
When I read on the vldc5 TE shows 94 and TE1 shows 0 and both values increase as I increase the power by rotating the cranks, the motor works on walk mode, but when I paddle the torque sensor doesn't make the motor rotate.
From what I can understand the torque sensor is connected to the controller and the communication goes to vldc5 and when I use walk mode the communication goes to the controller, so communication between vldc5 and controller it's working. H-bridge or ESC on the controller are working otherwise the motor wouldn't work on walk mode.
Can someone help me troubleshoot why the motor it's not working?
Thanks
Thanks
