rogerleurs
10 µW
- Joined
- Mar 9, 2022
- Messages
- 5
I have a problem with 1 of 2 bikes i have build with a TSDZ2 36v 250w 6pins VLCD5
1 When i power on the bike I do have pedal assistance but only at 1 power assist level. It makes no difference which position the power assist level is in (1,2,3,4 and even off).
2 pedal assistance stops at 25 kmh. It is set up to work to 45 kmh and this earlier worked perfect.
3 When i disconnect the speed controller pedal assistance works to 45 kmh but only at 1 strengt (see 1.)
4 Torque sensor reads 92 without pressure
5 Torque sensor reads up to 160 with pedal pressure
6 Sometimes the motor works without problems for a short time, but 95% of the time does the problem exist.
I have asked the seller (PSWPOWER) and they advise to change the torque sensor. In my opinion the torque sensor works perfectly, Anyone seen this problem before? I have read a lot of articles but did not find the solution. Do you think i have to replace the controller or the display?
I hope anyone can help me, the only other choise i have is to change parts from one bike to the other but that is a lot of work, ik have build all the cables in the frames. Thank you in advance!
