TSDZ2: How to Set Odometer?
PeteCress
Paoli (near Philadelphia) Pennsylvania USA
Open-Source Firmware Version 20.1c-22
When I go to Settings/Various/Odometer and change the number, it jumps to 1,400-and-some miles when I exit "Change" mode.
IIRC, I succeeded in changing the odometer value once in the past, but do not recall doing anything different.
What might I be missing?
I don't have the direct answer for you, but in case no one else comes along with that, have you checked the big OSF thread(s) for this issue? Some of them are listed in this search
and this archive search may show more, and there are other possible search terms/etc that could find better info.
Big thread indeed!
I found a post by the developer that said v0.20.1c-4 contains a fix for the problem.
Thanks!
Now all I have to do is:
  • Find out where to DTL that version from
  • Figure out how to make my little PC/Motor hardware interface thingie flash the motor's mobo.
TSDZ2 Motor Controller Firmware Programming has some pretty explicit instructions, but I still can't make it work - I suspect bco I have the pinout connections wrong.
